Torque
130,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
RAFCHAR
What is the torque on the intake monofilament bolts?
Please
Sep 20, 2016 at 5:38 AM
JIS001
  • 3,412 POSTS
Tighten the bolts in the sequence shown.
Tighten the lower intake manifold vertical bolts to 7 Nm (62 inch lbs.) .
Tighten the lower intake manifold diagonal bolts to 13 Nm (115 inch lbs.) .
The upper plenum. Tighten the bolts to 25 Nm (18 ft. lbs.)
Sep 20, 2016 at 5:50 AM
RYAN L
  • 273 POSTS
Thank you for using 2CarPros.com! If you have any other questions about your vehicle post a new question using this link https://www.2carpros.com/questions/new We are always here to help!
Sep 20, 2016 at 7:19 AM
