What are the Torq specs for the piston Rods and bearings?
45,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
ZIONEX5
Hello Guys, I am looking for Torq specs for piston Rods and bearings.
Dec 21, 2022 at 11:28 PM
  • 110,248 POSTS
I'm sorry, but this vehicle isn't offered in the US. Interestingly, the model year 2013 is the last year for them in the US.
The closest thing I have isn't any good for you. It's a 2013 2.0L. I attached them for you to see but that is the newest thing I have.
See pic below.
Dec 23, 2022 at 3:39 AM
BORIS K
  • 836 POSTS
Below is the specification for the 1.4 Boosterjet engine, K14C
Note always replace stretch bolts
All tightening specs below have degree tightening specs so this would indicate that new bolts will be required.
Tightening torque:
Big-end bearing cap
Stage 1 15Nm
Stage 2 loosen all bolts to 0Nm
Stage 3 25 Nm
Stage 4 55 degrees
Main bearing cap
Stage 1 20Nm
Stage 2 40 Nm
Stage 3 60 degrees
See image 2 below for main bearing tightening sequence
Cylinder head
Stage 1 15Nm
Stage 2 30 Nm
Stage 3 70 degrees
Stage 4 65 degrees
See image 1 below for cylinder head bolt tightening sequence]
To tighten bolts to degree specification please use an angle gauge, see image 3
Hope this helps.
Cheers, Boris
Dec 23, 2022 at 8:26 PM
