Convertible top will not operate
123,000 MILES • V8 • 2WD • AUTOMATIC
CHERBYL1
Hi, my sc430 top won't operate and the light on the switch doesn't operate either.
May 14, 2019 at 6:26 AM
  • 55,616 POSTS
There are five fuses that run the system. here are the convertible top wiring diagrams so you can see how the system works and a guide to help you check for power at the fuses with the fuse locations as well. The fuses you need to check are at the top of the diagrams.
May 15, 2019 at 7:09 AM
