How to find top dead center
205,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
DYCAR2008
  • 18 POSTS
How do you find TDC on the vehicle listed above DX SOHC? Thank you
Jan 17, 2020 at 10:37 AM
  • 110,248 POSTS
If you are just trying to locate TDC with the engine together, on the crankshaft pulley, there is a notch. It needs to be aligned with 0 degrees or TDC on the indicator located on the timing belt cover. I attached a pic.
If you are replacing the belt or trying to install the distributor, let me know. With the timing belt cover off, you need to use different marks, so let me know if that is what you are doing.
I hope this helps.
Jan 17, 2020 at 2:25 PM
DYCAR2008
  • 18 POSTS
I am trying to install a distributor. so what marks do I use?
Jan 18, 2020 at 3:43 AM
  • 110,248 POSTS
You will need to have the crankshaft on TDC and when installing the distributor, the rotor should point at where the number 1 spark plug wire will be in the distributor cap. Here are the directions. I attached a picture and circled the number 1 spark plug point on the distributor cap.
_____________________________
REMOVAL
1. Remove high tension leads.
2. Disconnect wiring harness.
3. Turn crankshaft to #1 cylinder TDC.
4. Remove mounting bolt and lift off distributor. Do not turn engine while distributor is removed.
INSTALLATION
Install in the reverse order of removal and note the following:
1. Coat the O-ring with engine oil.
2. Ensure that #1 cylinder is at TDC.
3. Align distributor drive blade with slot in camshaft.
4. After installation, adjust ignition timing (see Adjustments).
5. Tighten mounting bolt to 14 - 19 ft lb (19 - 25 Nm).
______________________________
Once installed and the engine starts, you will need to fine tune the timing. You will need a timing light to do this. Here are the directions. The last two pics correlate with these directions.
1993 Mazda Protege L4-1839cc 1.8L SOHC
Ignition Timing
Vehicle Powertrain Management Emission Control Systems Adjustments Ignition Timing
IGNITION TIMING
PREPARATION
Diagnosis Connector
pic 2
1. Warm engine to operating temperature.
2. Turn all electrical loads "OFF."
3. If using Mazda System Selector (SST #49 B019 9A0), connect to diagnosis connector. Set switch "A" to position "1" and test switch to "SELF-TEST" position.
4. Connect tachometer and timing light.
NOTE: If Mazda SST is not used, install a jumper wire between diagnosis connector "TEN" and ground terminals.
ADJUSTMENT
Timing Adjustment
pic 3
1. Following preparation, check if timing mark (yellow) on crank pulley is aligned with mark on timing belt cover:
5° ± 1° BTDC
2. If adjustment is required, loosen lock bolts and turn distributor as needed to align timing marks.
3. Tighten lock bolts to 19 - 25 Nm (14 - 19 ft.lb).
4. Following adjustment, remove SST or jumper wire.
I hope this helps. Let me know if you need anything.
Jan 18, 2020 at 9:57 AM
DYCAR2008
  • 18 POSTS
In order to have the #1 cylinder at TDC. does this mean having the notch on crankshaft pulley aligned with 0 degrees on the timing belt cover ? thanks
Jan 18, 2020 at 11:26 AM
  • 110,248 POSTS
Yes. The 0 indicates TDC (0° before or after TDC). You will notice there are numbers with degrees both before and after the 0. When you use the timing light, that notch will light at some point on the cover. Then you can move the distributor one way or the other to achieve the correct timing. The procedure indicates 5° BTDC. That means the spark plug will spark 5° before the piston actually reaches TDC.
I hope that makes sense. Please feel free to let me know if you have other questions.
Joe.
Jan 18, 2020 at 12:43 PM
DYCAR2008
  • 18 POSTS
what size socket do I need to use on crankshaft pulley in order to turn it? Thanks
Jan 26, 2020 at 7:19 AM
  • 110,248 POSTS
I have no way to reference that without being there. It isn't something listed in a manual. If I had to guess, I would say it will be near 22mm.
Jan 26, 2020 at 10:15 AM
JOHN VANG
I have a 2003 Mazda Speed Protege, and I have to switch out the crankshaft sensor. What tooth on the crankshaft do I have to line up with the new crankshaft position sensor once I’m at TDC?
Oct 1, 2021 at 7:43 AM
  • 110,248 POSTS
If you are only replacing the sensor, there is no need to worry about timing. The sensor reacts to a toner ring that isn't adjustable, so the engine timing can't change that.
Simply remove the old one and install the new one.
If you look at the attached pic, it provides the directions specific to this vehicle for sensor replacement. Also, here is a link that explains in general how it's done:
See pic below.
Oct 1, 2021 at 1:27 PM
