Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Cruze
Engine
Timing Chain
Guide
Tool size for timing chain bolt
2012 CHEVROLET CRUZE
75,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
BWHUOT63
MEMBER
For the timing chain guide bolt part # 90531117, what type socket and size do I need?
Oct 5, 2020 at 9:02 PM
Experienced Mechanic
Good morning,
I attached the set of sockets you will need. They do not specify the exact size of the socket but they are torx sockets. The hole set is $10.00.
I attached a picture of the bolt. Is this what you are referring to?
https://www.harborfreight.com/38-in-drive-star-bit-socket-set-6-pc-67886.html?_br_psugg_q=torx+socket
Image (Click to enlarge)
Oct 5, 2020 at 10:12 PM
BWHUOT63
MEMBER
I believe so, the bolts are located in the valve cover.
Oct 6, 2020 at 12:11 AM
BWHUOT63
MEMBER
Video.
https://youtu.be/p9S6qm2Gc6Y
Oct 6, 2020 at 12:18 AM
In the valve cover? Please explain.
Can you upload a picture for me to view?
Oct 6, 2020 at 12:22 AM
Sorry, I just got the YouTube video of you finding the issue.
Good find. It is never common for the plugs to be loose unless they were never torqued when installed.
Oct 6, 2020 at 8:20 AM
Add image or video
Ask a new question
Engine won't start
Engine overheating
