Replacement engine when warm starts missing?
298,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
FIREFITR
  • 5 POSTS
I just put another 3.0 in my truck. it starts up and runs great until it starts to warm up the it starts to miss and actually gets way too much gas, I had to change the plugs in it. but also I had to unplug the mass air flow sensor, it wouldn't even start with that plugged in.
Any Ideas?
Apr 25, 2019 at 12:12 AM
BMDOUBLE
  • 1,139 POSTS
Make sure that the mass airflow sensor is not contaminated. You can clean it out with either brake clean or the special cleaner that they sell at the auto parts store. Also be sure to transfer the original fuel rail to the new engine as the injectors can be different from certain year models, I’ve actually fixed a few for that issue. Another issue that I have seen is that the cam synchro gets out of sync. They make a special tool for it but if your scanner will do a power balance test you can align the synchro by pulling #1 plug wire and turning it until it shows as a miss on #1 on your screen.
Apr 25, 2019 at 12:59 AM
FIREFITR
  • 5 POSTS
I cleaned the MAF sensor plugged it back in and the truck starts up and shuts down in about a half second.
I unplug the MAF and it starts and runs until it starts to warm up, then it starts to flood out.
Apr 25, 2019 at 1:35 AM
BMDOUBLE
  • 1,139 POSTS
Are there any trouble codes in the PCM?
Apr 25, 2019 at 12:30 PM
FIREFITR
  • 5 POSTS
nope.
Apr 25, 2019 at 11:37 PM
  • 55,766 POSTS
If I can jump in here. I have seen the engine coolant temperature sensor short out causing the PCM to go rich. This condition may or may not create a trouble code. Here is a guide to help walk you through the the steps and diagrams below to show you how on your car:
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
Apr 29, 2019 at 5:21 AM
FIREFITR
  • 5 POSTS
that sensor is brand new and the wire has voltage to it. I have a pretty good idea that the MAF sensor is bad cause when you plug it in the truck wont start and when its not plugged in the truck runs but blows a lot of black smoke and fouls out the plugs
Apr 30, 2019 at 10:44 PM
BMDOUBLE
  • 1,139 POSTS
sounds like you’re on the right track with the MAF sensor.
Apr 30, 2019 at 11:39 PM
  • 55,766 POSTS
I agree with BMDOUBLE, please let us know.
May 1, 2019 at 5:26 AM
FIREFITR
  • 5 POSTS
That's what it was,Put a new MAF sensor on and now its running like a Champ
Thanks for the help
May 1, 2019 at 11:47 AM
  • 55,766 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
May 2, 2019 at 6:08 AM
CHARLIE81188
Engine Performance problem
2000 Ford Ranger 6 cyl Four Wheel Drive Automatic
The truck miss fires only at a stop, and its every so often. I have changed my intake gasket, pvc, plugs. I plugged off my pvc with a bolt for a minute aand the code changed to being to rich. And still miss firing and burning lean. And also there is a code that comes up as monitor miss fire fault.(I think thats what it said.) I dont want to go and spend a hole lot of money pn o2 sensors if i dont have to so could you please help
May 2, 2019 at 6:09 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
should scan for codes
codes should point to troubled area or help in pin pointing to what is happening and put you on the write track to fix and correct the problem
NEGOTIVE00
Transmission problem
2000 Ford Ranger 4 cyl Two Wheel Drive Automatic
Hi, i am currently having problems with my trans on my 2000 ranger. When i start driving it seems fine, but after it warms up the trans will start to skip and the OD light will start to flash. I tried doing a fluid and filter change on the trans, and i switched out all the sensors in the base of the trans, but that didn't change anything, then i changed the speed sensor on top of the pumpkin in the rear, the problem actually got worse when i did that, it would go into "hobble mode" so i put the old sensor back in and it's back to the old skipping. It seems to skip more when going up hills. I am just about out of ideas except for maybe the trans control solenoid or changing out the trans entirely. Any ideas would be greatly appreciated. Thanks!
2CARPRO JACK
  • 11,533 POSTS
To take the guessing out of it, have the PCM scanned for trouble codes.That is what the blinking OD light is telling you, it sees a problem.It should have a trouble code stored in memory that will lead to the root of the problem
ROBERT HAMILTON
Engine misses occationally at startup, when accellerating, and when crusing. Tach sometimes reads zero, but not always when problem occurs. Replaced wires, spark plugs, and air filter. Problem cleared up for 2 weeks, but is getting worse now.
Gas mileage hasn't changed.
BMRFIXIT
  • 19,053 POSTS
possible bad ignition wires (defective )
do u have check engine light on and if so need to have it scanned for codes
KENT MARTIN
2000 Ford Ranger 6 cyl Four Wheel Drive Automatic 75K miles
Engine misses at Idle and low RPM (<10 mph). Once moving 2000 RPM miss seems to stop, but returns when idleing down.
Ford change intake manifold gasket at $$00.00 plus and miss came back.
Local Mechanic said the computer under the dask was bad and ordered one from Ford for 700.00. Ford didn't know how to program so we cancelled order.
Lost???
Thanks
Kent Martin
Ruidoso, NM
Jul 29, 2020 at 4:07 AM (Merged)
  • 55,766 POSTS
Ford had problems with fuel injectors that would effect the idle. Unfortunately there is no easy way of testing them for that problem. You may have to replace them.
SCRAPPY52
i replaced the #1 injector lastnight and it didn't fix the problem the computer, every time the engine light comes on tells me its bank 1. But it could be another injector and it would show up in codes?
JEFF CLARK2
Replaced injectors and started engine ran smooth, then stated popping and condensation coming out tail pipe and very ruff idle. did start looking into it very deep yet, but narrowed the misfire on four, five and six? Unhooked harness to replace valve cover gaskets thanking one of the injectors is shorted and I unhooked battery during the time. I replaced everything do I need to reset the computer.
HMAC300
  • 48,601 POSTS
scan for codes first and check fuel pressure with a gauge auto parts rent it. but for misfires it is better for a mechanic to diagnose as it can be a myriad of things so you do not waste money on parts that may not be anything wrong with them. See link.
JBOISCLAIR70
Check engine light came on with a ignition coil code. But saying misfire on cylinder six.
Jul 29, 2020 at 4:32 AM (Merged)
PATENTED_REPAIR_PRO
  • 1,853 POSTS
What are the codes?
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Were they P0306, P0356 and/or P0353?
JBOISCLAIR70
P0306.
PATENTED_REPAIR_PRO
  • 1,853 POSTS
P0306 is not an ignition coil code it is a misfire on number six cylinder, although it could mean the ignition coil is bad if this has a coil on each cylinder (coil on plug).
MARTINA
When I apply my brakes the brakes seem to skip - almost like anti lock isn't working - what do you think is wrong
MERLIN2021
  • 17,250 POSTS
By skip, do you mean pulsating? Steering whell shake at higher speeds when you brake? Or pedal bouncing? If yes the rotors are warped...
JBOISCLAIR70
I meant to write thats what someone said to change. I did plugs and wires about 7 months ago.
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Swap the coil with another cylinder and see if the misfire moves or stays on #6. If it moves then the coil is bad, but if it stays then the coil is fine and something else.
CHUKAWOMP
when I start my truck It has a miss and seems like it is only running on five cylinders. could there be a bad censor somewhere? Thank you
BMRFIXIT
  • 19,053 POSTS
sensor ? will not give u a misfire
injector will
spark plugs will
wires will
1st step check it for tune up / scan for code s
OSINMS
2000 ford ranger 4l /// 220,000 miles has always ran like a champ. I had the codes read and found out # 1
cylinder was missfirering. Changed plugs//wires//and replaced all injectors. i have always kept the maintentance up on this vehical...any help would be welcome...
thanks ottis
BACKYARDMECHANIC
  • 337 POSTS
You have covered much of what can cause a misfire but here are a few things that can also cause a misfire. Does your car have a distributor? If it does than I suggest you change the cap a rotor also. If you don't have a distributor then you have coil packs. The one for the #1 cylinder could be bad. Swap a coil from another cylinder and see if the misfire moves to that cylinder. Poor compression can also cause a misfire. Do a compression test on all cylinders and compare your results to each cylinder. If the car idles poorly check the engine for a intake vacuum leak. This can also cause a misfire
