torque pressure
14,700 MILES • 5.7L • V8 • 2WD • AUTOMATIC
BARBARA1963
  • 99 POSTS
What is the torque pressure on the rocking arm bolts?
Jul 3, 2016 at 9:26 AM
good morning my name is Roy and I will help.
there is no torque. It is a process to adjust each valve. you need to be sure the valve is totally closed by rotating the engine. then tighten the rocker nut until the push rod feels tight. then tighten one full turn. this needs to be done to each valve.
Vehicle » Specifications » Mechanical Specifications » Engine » Cylinder Head Assembly » Valve Clearance
Valve Lash Rotate the Valve Rocker Arm Nut Clockwise 360 degrees (1 Turn) from Zero Lash.
Jul 4, 2016 at 12:54 AM
