today's technologically advanced old cars don't pollute as much as the rusty bulky old cars of the 1970s and 1980s did, do they?
86,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
ALEX STATHAS
  • 71 POSTS
even if the variable valve timing sprockets and variable valve timing solenoids malfunction, even if the upstream and downstream exhaust gas oxygen sensors and other sensors malfunction, and even if the silicon plate circuit board malfunctions and causes the engine to run rough or run poorly the engine still won't emit as much pollution as the old humongous rusting hulks of the 1970s and 1980s did, will it? there is no need for a smog test as today's old cars like my 9-year-old Nissan Versa SV control pollution on their own through sequential electronic fuel injection, coil-on-plug ignition, double catalytic converters or three way catalysts, is there a need for a smog test with today's modern old cars? it just needs three-month interval bulk synthetic oil changes at Walmart since it is otherwise technically advanced, doesn't it and otherwise it doesn't pollute doesn't it?
Mar 6, 2023 at 3:20 PM
CARADIODOC
  • 34,413 POSTS
Where did you come up with those ideas? There's dozens of ways brand new cars can pollute. That's like saying we don't need courts to try murderers because there are laws against murdering people.
The majority of car owners today have no clue on how the machines they trust to get them back home work, and they have no idea how to maintain them. There's two parts to the emissions story. The first part is keeping to a minimum the amount of pollution that will be developed. Ideally that would be zero, and in fact, you can suck on the tail pipe of today's cars and live to tell about it. The second part has to do with addressing those pollutants that still do get developed in spite of all that technology.
Car owners have tried to defeat many of those systems in the misguided attempt at gaining power or better fuel mileage. The world of automotive marketing is so extremely competitive, you can be sure if a manufacturer could advertise one more mile per gallon, one more inch of headroom, or one more horsepower, you can be sure they'd do it. No one is going to buy one model over another because they advertise one less ounce of pollution.
Have you ever thought about why an old Chrysler 318 c.i. engine could power a motorhome away from a stop sign or up a hill, while that same engine could get a police car up to 120 mph? The simple reason has to do with camshaft timing. Two degrees retarded will seriously increase low-end torque for pulling a load, but at the expense that you'd need a mile or more to pass someone at highway speed. Two degrees advanced will make a police car go from 0 to 60 mph like any old 6-cylinder engine, then it would tear the seats off the hinges from 60 to 90 mph. I had one of each. Standard camshaft timing is a compromise between high low-end torque and high high-end torque. To make that change in cam timing requires tearing down the front of the engine. Instead, the engineers designed the variable valve system that gives us both from a smaller engine that uses less fuel. We don't have to whine and snivel about it. We just have to change the oil when we're supposed to, which, by the way, is a lot longer interval than the standard 3,000 miles from years ago. Oil technology improves all the time too.
Your unrealistic comment about three-month oil changes doesn't stand to reason. I have a '93 Dodge Dynasty, bought new, that now has less than 5,000 miles. It has gone years at a time with no battery and not starting the engine. Should I have been changing the oil every three months? I put about 4,000 miles per month on my 2014 Ram. Should I ignore the oil for three months?
We use upstream oxygen sensors to tell the Engine Computer how much unburned oxygen is in the exhaust. The computer uses that information to adjust how long it pulses the injectors open. We also had oxygen sensors, for the same purpose, as far back as the late 1970s on carbureted engines. That's how the little peppy Horizon Miser got an easy 54 mpg with little pollution.
I have to admit, the engineers have found solutions through the extensive use of unreliable computers where there were no problems, but I would never want to go back to the days with no Engine Computers. You understand parts and systems fail all the time. One of those systems is the exhaust system with its catalytic converter. There's a unit that can easily last the life of the vehicle, except owners will ignore a misfiring engine that leads to a melted catalyst, then some genius will hollow it out, making it totally ineffective. Now you have increased pollution that you think can't happen. Believe it or not, some of our over-educated politicians were demanding the manufacturers design the systems to shut the engines down if pollution went too high. It took some serious lobbying to convince them that shut-down might occur in the middle of a busy intersection, on a deserted country road in the middle of nowhere, on a dark Saturday night, or in the bad part of town. Instead, they came up with the downstream oxygen sensors. All they do is monitor the efficiency of the catalytic converter, nothing more.
Every mechanic who has been around for a few years can relate stories of cars with black electrical tape over the Check Engine light. Way too many people think when that light turns on, the computer will tell you which part to replace. They become frustrated when the light turns back on with the new part installed, so they just cover up the light. Now they have no way of knowing if or when a new problem occurs that could be very minor, but turn into an expensive one when it gets unwittingly ignored. I just answered a question yesterday where the owner has been driving for weeks with a flashing Check Engine light, and wanted to know what to do. And you believe cars can't develop problems that make it necessary for government to step in and make us clean them up?
By your own admission, cars today are a lot cleaner than the older cars, but why is that? It's because of all that technology that you think can break down without consequences. I detest government involvement in every aspect of my life, but with cars and pollution, we've shown them we can't be trusted to keep these systems working properly. They force us to get them inspected to prove I'm not polluting the air you're going to be breathing. Without a little regulation, would you trust your neighbor to keep his car clean?
I also question your assertion about older cars. Why do you suppose they polluted more? It's because we didn't have the technology back then that we do today, we didn't have the testing that we do today, and it was easy to disable or ignore the anti-pollution systems we did have. We also had smog. You'll find the opposite at old car shows. Old rusting hulks don't show up there. Instead, we have meticulously restored vehicles that are tuned to perfection using modern equipment. Most are infinitely cleaner than when the popped off the assembly line. Every single one of those old rusting hulks from the '70s had a charcoal canister to absorb gas fumes and prevent them from going into the air, but every one also had dry-rotted rubber hoses and rusted hose clamps. Every single one leaked gas fumes when just sitting in the garage. Today we have technology for insuring that system doesn't have a leak. You won't find those rotted hoses on restored cars.
You'll have a hard time convincing car owners all that's needed is regular oil changes and no periodic inspections. That means all we need are a bunch of low-trained lube jockeys, and no mechanics. Why then are all the reputable shops' parking lots full of waiting customers?
You said "even if all these high-technology systems malfunction, the pollution still won't be as high as, . . . ". Wonderful. So the smog in Los Angeles will be less than it was in the 1960s, but that's good enough. Every single car is going to have part of one of those systems fail in its lifetime. More realistically, there will be over a dozen failures in a car's lifetime. We know if there were no inspections, most of those problems would never be repaired. We know most of those failures would add to pollution.
I have plenty to complain about new cars and the unnecessary use of unreliable technology, but there is no way to defend an argument against proving my car is as clean as it's supposed to be.
I have a gripe about the extremely customer-unfriendly business practices of some manufacturers. I also complain about the use of computers where they aren't needed and were never intended to be needed. No one is arguing that they want less pollution control. You're arguing against proving your car is clean, (which isn't difficult to do). I win.
All of these systems you mentioned reduce pollution in some way, but we know they do break down at times. That means whatever they were doing to reduce pollution, they aren't doing it now. Obviously that means pollution has increased. I might not care enough about you to fix my car unless someone forces me to.
Years from now some people will be complaining about those old days when we drove those miserable polluting 2023 models. They will smugly point to their electric cars, but forget those are just one link in the giant chain of polluting events. We're already being asked to charge our cell phones at night because the power plants can't keep up. How in the world are we going to charge millions of electric cars unless we build new nuclear power plants, or as China is currently doing, building over 1,000 new coal-fired plants? And guess what? Those plants go through inspections a whole lot more rigorous than what your car goes through. Well, at least ours do.
If you still think inspections are a bad idea, consider that many of the tests are performed on-car, by the Engine Computers now Rather than stuffing a probe up the tail pipe, all that's needed is to see that all the on-board monitors have passed, then you're on your way. That takes less time than stopping for gas. Today, proving your car is not polluting is real easy, unless it has a problem you don't want to address.
Mar 7, 2023 at 5:14 AM
ALEX STATHAS
  • 71 POSTS
very wordy dear Caradiodoc, I am very lucky and very fortunate that Florida doesn't require exhaust emissions inspections for registration, I shouldn't have to pay hundreds or even thousands of dollars to replace variable valve timing parts or electronic fuel injection parts or coil-on-plug distributorless ignition parts that are still working but are not working properly and a $58 dollar bulk synthetic oil change from Walmart every three months should suffice to keep the engine from seizing up, as for the miles we are putting a little bit less than 3,000 miles every three months but I admit that your vehicle you mentioned that you put 4,000 miles every single month it needs oil changes every single month rather than every three months and that's not my recommendation that's the Walmart Supercenter's recommendation but by following the Walmart recommendation on bulk synthetic oil changes I have avoided engine noise or the engine seizing up, a variable valve timing sprocket is almost $1,000 dollars at the Advance Auto Parts discount store while the variable valve timing solenoid is almost $500 dollars and a single direct ignition coil is almost $150 dollars, should I have to pay for all this technological stuff just because of a slight uptick in pollution? Florida is not tough on motorists but it is very tough on crime and at the beginning of your wordy reply you talked about murderers and tough Florida recently executed one who was claiming to speak for the people and had claiming that Florida governor Ron DeSantis has his boots on the necks of the people, let me tell you the liberal States have their boots on the necks of motorists with exhaust emissions inspections requirements while the liberal States are soft on crime and on murderers, that's all Caradiodoc and wish me a happy and long and prolonged motoring in Florida that goes easy on motorists but is very tough on crime
Mar 7, 2023 at 6:43 PM
CARADIODOC
  • 34,413 POSTS
Listening to your comments that turned political, if I was in Florida again, like I was a year and a half ago, I would hunt you down and give you a huge hug! I want Trump back in the worst way, but if I can't have that, I'd be satisfied taking your governor away from you and putting him in the White House. As a caller from northern California told Rush Limbaugh a few years ago, they were held hostage by the liberal voters in the big cities. Up here in Wisconsin, we have the same problem with Madison and Milwaukee. In my northern area, it was real easy on a road trip to count four to six dozen Trump yard signs and not a single Biden sign, yet we somehow went for Biden. Can't find anyone around here who will admit to voting for Biden, yet my county was listed as going to him.
To address your parts issues, failures of the parts you mentioned do not cause minor hiccups. They usually leave you sitting on the side of the road or with reduced power and greatly increased fuel consumption. I help a friend at times in his overgrown body, farm implement, and auto repair hobby shop. What he sees over and over are failures that have little to do with all this technology and way more due to poor designs. Case in point is timing chain failures on low mileage GM vehicles. He specializes in rebuilding smashed one and two-year-old Dodge trucks, but they've been bringing too much money the last few years. All he can afford to buy were GMC Acafdias, one with less than 28,000 miles, and all three turned out to have major engine problems. A nearby salvage yard has 50 of them. 49 have bad engines. The engine was gone from the 50th one.
My gripe has to do with computers that need to be programmed to the VIN, and at least with GM vehicles, only the dealers can do that. With my old rusty trusty '88 Grand Caravan, to solve one of those "minor" problems of the cruise control not working at times, all it took was a used $25.00 Engine Computer with no programming. Popped it in and set off into the sunset.
By the way, (disclaimer here. I'm not recommending this to anyone), there was a knocking in the engine in that Caravan to the point people got out of my way in parking lots to avoid flying parts. Under the assumption I was going to have to have my students rebuild it anyway, I stopped changing the oil. When no failure occurred, I finally changed the filter every other year, and added a quart of oil every 1,000 miles. That got me enough additives replenished to keep the engine happy. That van went 14 years with no oil change. It reached 440,000 miles before it got so rusty, the carpet was the only thing holding the front and rear together. I've been looking for a rust-free replacement with factory 15" wheels for a few years. Got any running around by you?
Be aware too, Chrysler has been the world's leader in innovations that benefit car owners, from the first "AC generator", (they copyrighted the term, "alternator", (1960), the first electronic voltage regulator, (1970) first electronic ignition, (1972), lock-up torque converter, (1977), Engine Computer, anti-lock brakes, (1969), and air bags. GM was the first to refuse to allow me to buy their radio service manuals, first to limit access to module programming, and the first for almost everything that benefits GM over the best interests of their customers. I can't even begin to discuss Ford's designs with steering parts that fall apart in 15,000 miles or many of their other horrible designs. Instead, I'm going to head home now and pout.
Mar 8, 2023 at 11:07 AM
