HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Buick
Century
Engine
Symptoms
Misfire
Too much water in lines
MARIE HARTJE
MEMBER
1993 BUICK CENTURY
210,000 MILES
My car may have water in the lines. It starts barely and chugs barely then it cuts out.
Monday, April 10th, 2017 AT 10:24 PM
HMAC300
MECHANIC
Scan for codes and check fuel pressure with a gauge. it may be anything I doubt it is water in lines. See link as it is more than likely a fuel pump problem or regulator.
SPONSORED LINKS
Tuesday, April 11th, 2017 AT 6:13 AM
Please
login
or
register
to post a reply.
Related Engine Misfire Content
1993 Buick Century Misfiring At Slowed Speed Or Stop
I Have A 1993 Buick Century That Runs Good, Doesn't Smoke, Leak Fluid, Etc. However, When Taking Off From A Stop, It Will Hesitate...
Asked by
awrbulldog
1 ANSWER
1993
BUICK CENTURY
VIDEO
Intermittent Misfire
Instructional repair video
GUIDE
Misfire Random Code P0300
The world of automotive diagnostics can be complex, with numerous codes and potential issues to keep track of. One of the more common engine diagnostic codes is P0300, which...
1993 Buick Century Missing On One Cylinder
New Plugs, New Wires, Changed Computers, Checked Compression, Mechanic Said Injectors Was Ok. Got Any Suggestions?
Asked by
sharon lowry
1 ANSWER
1993
BUICK CENTURY
2005 Buick Century Random Misfire
I Have A 2005 Bucik Century That Is Very Hard To Start And Is Running Extremely Rough. I Can The Codes And Found Code Po300 For Random...
Asked by
Justin U
2005
BUICK CENTURY
2000 Buick Century Car Is Missing
My Buick Is Missing And The Check Engine Light Is Coming On Mainly When It Gets Hot Outside Or The Engine Gets Warm When It Is Cold Outside...
Asked by
bullfrog78
1 ANSWER
2000
BUICK CENTURY
1999 Buick Century Diagnostic Code Cylander 2 Miss...
Went To Local Auto Repair Store And They Got The Code Cylander 2 Missfire And Advised Me To Change Spark Plugs Then Wire Then Coil Pack. We...
Asked by
lishamathews
1999
BUICK CENTURY
VIEW MORE
SPONSORED LINKS
How to Repair an Engine Cylinder Misfire
Online car repair manuals
