Titan Head Gasket Sealers & Oil Stop Leaks
2002 MITSUBISHI ECLIPSE
178,000 MILES • 3.2L • 6 CYL • AUTOMATIC
LUANN NEEDHAM
Will this brand of sealer work for my car?
Nov 2, 2018 at 6:19 AM
I am not familiar with this brand; in that I have not used it before.
However, before you try any of these sealers you want to confirm this is a head gasket. If you have coolant and oil mixing, then it could be a cooler issue as well so here is a test that we can use to confirm this:
If you confirm the head gasket is the issue, then here is a guide that reviews one of these sealers that is claimed to be the best.
https://www.youtube.com/watch?v=Xi41RFMP8Ow
Please run through this info and let us know what questions you have. As for this specific brand that you asked about the only advice, I can give on that one is to stick to the reviews and if it is highly rated then it may be worth a try.
Apr 20, 2022 at 4:54 AM
