Car not driving properly after installing incorrect size winter tires?
96,000 MILES • 4 CYL • 2WD • AUTOMATIC
SONATA98
I put too big of winter tires on my car and went back to my normal size summers and my cars has been driving weird ever since. when I first got the car it drove like it was brand new.
Dec 20, 2023 at 12:19 PM
  • 110,248 POSTS
How would you best describe how it is driving? Also, are all tires the same size and in similar condition?
Let me know what it is doing that seems odd. Also, how much bigger were the tires and did they rub when the vehicle moved?
Dec 21, 2023 at 2:52 PM
SONATA98
The tires were 235/65/17 and there was rubbing. Sometimes it feels like my brakes aren’t that great and other times they work good, but I had my whole brakes serviced and looked at they were fine.
Dec 21, 2023 at 11:59 PM
  • 110,248 POSTS
If it feels like a drag, are there any strange odors or sounds? For example, do you ever notice a humming sound or other noise?
When the brakes don't feel that great, could the ABS be turning on? I'm asking because if the tires rubbed, something could have happened with the wheel speed sensor wiring.
Dec 22, 2023 at 11:12 AM
SONATA98
I do sometimes get a rotten egg type smell but it’s not that often and I do here some noises sometimes in the wheel areas.
Dec 22, 2023 at 11:37 AM
  • 110,248 POSTS
The smell could indicate you have a problem starting with the catalytic converter. It may be starting to plug. That would cause a power loss.
The noise you sometimes hear, can you describe it?
Dec 23, 2023 at 12:53 PM
