Tires wobbling when driving at low speeds
25,000,000 MILES • 0.6L • V6 • 2WD • AUTOMATIC
HOLDENGRL
Feels like my tires are wobbling when driving at low speeds. I also know my sway bar links are stuffed.
Mar 14, 2022 at 10:40 AM
  • 110,248 POSTS
If you feel a wobbling, first make sure there is no damage to the tires. Check for shifted belts or a bulge in the tire.
If that is good, I need to understand what you mean by the stabilizer being stuffed. Are they broken? Also, when you feel the wobbling, is it a left to right feeling or up and down? Have you checked steering components including ball joints, tie-rods, and joints in the steering components?
I don't have the specifics on this vehicle because it isn't offered in the US. However, I'll try my best to help.
Mar 15, 2022 at 9:20 AM
HOLDENGRL
It's a side-to-side wobble. I changed my sway bar links yesterday and that helped a bit. Also, one of my back tires has a chunk out of it.
Mar 15, 2022 at 9:44 AM
  • 110,248 POSTS
Check to make sure the ball joints and tie rods are in good condition. I attached pics below of what you are looking for.
Mar 16, 2022 at 5:58 AM
