Tires?
270,000 MILES • 3.7L • 6 CYL • 2WD • AUTOMATIC
JGAN72
Will 31x11.50 AT tires fit without any modifications?
Mar 8, 2025 at 11:21 PM
  • 55,711 POSTS
Factory tire sizes range around 245/70R17 (30.5" diameter, 9.6" width) or 265/65R17 (30.6" diameter, 10.4" width). Stock wheel width: 7-8 inches.
Diameter: 31 inches, which is only slightly larger than stock and should fit without major issues.
Width: 11.50 inches, which is about 1-2 inches wider than stock and may cause rubbing on the control arms, inner fender liners, or suspension components, especially at full lock or over bumps.
Let us know if you need anything else.
Mar 10, 2025 at 4:03 AM
