Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Fusion
Tires
Size
Tire sizes
2011 FORD FUSION
85,000 MILES • 2.5L • 6 CYL • 2WD • AUTOMATIC
FLIPPA334
MEMBER
What is the difference between a 225/50/17 and a 225/50R/17?
Nov 29, 2018 at 9:14 PM
Experienced Mechanic
Good morning again,
The R designates radial. They do not or should not make non radial tires anymore.
Use the 225/50R/17.
Are you replacing with new or do you have an issue?
Nov 29, 2018 at 9:23 PM
FLIPPA334
MEMBER
Replacing and what is the rim diameter so I can replace them also?
Nov 29, 2018 at 9:28 PM
The 225 is the width of the tire that hits the road way.
The 50 is the aspect ratio or the distance from the rim to the top of the tire.
17 is the rim diameter.
Nov 29, 2018 at 9:51 PM
FLIPPA334
MEMBER
I meant the width and depth. Sorry about that.
Nov 29, 2018 at 10:05 PM
That is something you need to measure. I cannot see it from here.
With the tire removed, you measure the rim width with a measuring tape. It could be anywhere from five inches to nine inches.
Nov 29, 2018 at 10:12 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
