Will these rims and tires work on my vehicle?
115,200 MILES • 4 CYL • 4WD • AUTOMATIC
LAURA P
I have P205 70 R16 tires, a couple of the rims are buggered so looking at some free ones online there’s a set of rims with P245 75 R16 tires off a jeep Cherokee will these rims work.
Feb 9, 2025 at 3:11 AM
  • 55,711 POSTS
The P245/75R16 tires are significantly larger than P205/70R16 tires so you might have clearance issues. The bolt pattern should be the same along with the center alignment hole, but I would measure them to make sure.
Feb 9, 2025 at 9:11 AM
