Tire wear
103,000 MILES • 3.5L • V6 • 4WD • AUTOMATIC
KROBERTS1991
The inside edge of the rear tires both sides are wearing very quickly to the rest. The tires were put on ten months ago. The rear two are getting worse they have been rotated once about five months ago. I just had it in today for alignment check and they say it all checks out camber is good, toe is good. So any other ideas of what is going on? Maybe suspension issue shocks springs ride height?
Sep 14, 2018 at 9:25 AM
Good evening.
If they aligned it and they said it is good, they missed something.
Tire wear comes from either toe in or camber. If you had it aligned, they should have given you a print out of the specs. Can you post those results on this post?
Sep 14, 2018 at 11:29 AM
KROBERTS1991
Unfortunately, I did not get one today, but as soon as I can I could get the specs from the last check up. Shortly after I had the new tires rotated I believe is when it is from. As I was internet searching could some of the suspension issues I read about be a possibility. I am surprised that they maybe did not check some like that. Also they also said the Taurus does not have the camber adjustments. Thanks Roy
Sep 14, 2018 at 11:40 AM
The car does not have camber, correct. But if it is off there are ways to adjust it. It does not mean that they should let it go. They need to tell you and give you suggestion on how to fix it.
Shame on them for not making you aware of the specs being off.
They should have checked the entire suspension before aligning it. You cannot align it with worn or bent parts.
Most shops today just do the front end toe in adjustments and send you on your way. they try to blame pothole damage after you left for the tire wear that takes a few thousand miles.
Sep 14, 2018 at 11:47 AM
KROBERTS1991
Yes, I heard the pothole excuse I am going to try another shop. The reason I went back to this shop when I saw the way the tires were wearing was that they would work on it as warranty work which sounds to be just put it on the machine. If it says it is good they are done no other options or possible fixes. I just will not go back again and alignments is their specialty so they should know some other alternative fixes to the problem other than the machine only.
Sep 14, 2018 at 12:14 PM
Correct. They are not a specialty shop or they would have given you a print out when it was done.
Go to another shop and get a print out of the alignment.
Sep 14, 2018 at 12:19 PM
KROBERTS1991
Thanks again Roy, I will try another shop next week. I will get the past results this weekend when I go to another shop I will make sure to see on any possible fixes.
Sep 14, 2018 at 12:27 PM
Sounds like a plan.
You are welcome.
Always glad to help.
Sep 14, 2018 at 12:30 PM
