Tire size
220 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
LUKE LUGNORE
  • 26 POSTS
My son's car needs winter tires. The tire size on the vehicle is 205 55 16. my question, can I use 205 60 16 for winter tires what would be the deference between 55 and 60?
Nov 29, 2017 at 12:00 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Here is a chart that has the dimensions: https://goo.gl/JuzfHD
Click on specs!
The 205/55R16 overall diameter is 24.8".
The 205/60R16 overall diameter is 25.6".
Nov 29, 2017 at 6:54 AM
JSDORN
  • 12 POSTS
Will the 205 60 16 work on my 2017 Curze?
The 2017 Cruze also can use a 17 rim.
Nov 29, 2017 at 11:17 AM
LUKE LUGNORE
  • 26 POSTS
I am not getting a straight answer. I got dementions of both the 205 55 16 and the 205 60 16 tire. I just want to know if The 205 60 16 tire will fit my 2017 Cruze LT?
Nov 30, 2017 at 12:23 AM
  • 55,730 POSTS
Yes it will fit but you will have less freeboard becasue the 205 60 16 tire is a higher profile and will give you a little less room for the tire in the wheelwell. Please post a picture of the currant tire and rim so I can show you what I am talking about please.
Cheers, Ken
Dec 2, 2017 at 8:02 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Yes, the 60 series tire will be 0.8" taller, so not even 1 inch.
The thread widths on both are the same, 6.6"
Dec 2, 2017 at 8:36 AM
JSDORN
  • 12 POSTS
OK thank you.I have another guestion.I want to get rims for snow tires for his cruze.Do
all 16"Chevy rims have the same Bolt pattern
Dec 3, 2017 at 7:39 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
I would have to say no, because you didn't say just the 16" rims that fit your vehicle. I am sure there are different bolt patterns but tirerack says yours are 16x7" with a bolt pattern of 5-105, which I believe that is 105 millimeters. Also, there is a Offset of 40mm and a Backspacing of 5.590".
Here is the link to one of those wheels just to show you the specs, https://goo.gl/psMK5k
Dec 3, 2017 at 9:09 AM
