Tire pressure question
500,000 MILES
PAUL SHAHIDI
My front tires have pressures of 35 and 36 and back pressure are 42 and 36.
Is this safe to drive on a highway?
Sep 1, 2019 at 2:08 AM
  • 110,248 POSTS
Welcome to 2CarPros.
It should be fine to drive. However, you really should follow the manufacturer's recommendations. If you open the driver's door, there should be a label indicating the original tire size and recommended pressures. That is where I would set the pressure. Since the front tires and one of the rear tires are very close, I would just make all of them 35 psi until you can locate the label I'm referring to and set them to the manufacturer's specs.
Joe.
Sep 1, 2019 at 1:26 PM
