Tire pressure monitor, power steering, and scanning issues
2006 CHEVROLET IMPALA
99,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
CJA31186
  • 89 POSTS
The power steering pump makes a humming/whining noise when the engine is running. Do you know if this needs to be replaced or just bled? Additionally, the dash says tire pressure monitoring system. What could be the problem with that? Also, the car is not inspected yet. It needs an inspection done in NJ. I hooked up my scanning tool to the vehicle and found what I think are some potential issues. Can anyone tell me anything about the data below and potential fixes involved?
2006 Chevrolet Impala C = 5.3
I/M Monitors
Since DTCs Cleared
Misfire Monitor ok
Fuel System Mon ok
Comp Component ok
Catalyst Mon inc
Htd Catalyst n/a
Evap System Mon inc
Sec Air System n/a
A/C Refrig Mon n/a
Oxygen Sens Mon inc
Oxygen Sens Htr ok
EGR/VVT Sys Mon n/a
This Drive Cycle
Misfire Monitor ok
Fuel System Mon ok
Comp Component ok
Catalyst Mon dis
Htd Catalyst n/a
Evap System Mon dis
Sec Air System n/a
A/C Refrig Mon n/a
Oxygen Sens Mon dis
Oxygen Sens Htr dis
EGR/VVT Sys Mon n/a
DTCs (Codes)
P0513 ECM
Incorrect Immobilizer Key
HISTORY
MIL NOT REQUESTED
Since last key cycle NOT RUN
Since DTCs erased PASS/FAIL
C0899 ABS
Device 1 Voltage Low
HISTORY
MIL NOT REQUESTED
Since last key cycle PASS
Record Data
FRAME: 0 TM: 0.0
ABS LOAD(%) 20.0
ABS TPS B(%) 22.4
ABSLT TPS(%) 23.1
ACC POS D(%) 9.4
ACC POS E(%) 19.2
BARO PRS("HG) 30.4
CALC LOAD(%) 20.4
CAT TEMP11(°F) 752
CLR DIST(mi) 2
CLR DIST(mi) 2
CLR TRPS 3
CLR TRPS 4
CMD EQ RAT 0.999
COOLANT(°F) 203
ENG RUN(m:s) 00:28
ENG SPEED(RPM) 601
EVAP PURGE(%) 0.0
EVAP VP(H2O) -0.092
FUEL LEVEL(%) 24.3
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
IAT(°F) 100
IGN ADV(°) 11.0
LT FTRM1(%) 0.8
MAF(LB/M) 0.84
MAP("HG) 10.6
MIL DIST(mi) 0
MIL DIST(mi) 0
MIL STATUS Off
MIL STATUS Off
O2S11(V) 0.180
O2S12(V) 0.845
OBD2 STAT EU/CA
OUT TEMP(°F) 82
REL TPS(%) 12.6
ST FTRM11(%) -3.9
ST FTRM1(%) -3.9
THROT CMD(%) 16.5
VEH SPEED(MPH) 0
VPWR(V) 13.673
VPWR(V) 13.524
Sep 10, 2019 at 7:00 PM
94 TRANSAM
  • CAR REPAIR CONTRIBUTOR
  • 680 POSTS
Hi and welcome to 2CarPros.
Lets take all this in order.
1: The power steering pump will whine if it is sucking air. Make sure the fluid is full. The only way to bleed that system is to make sure the fluid is full and then turn the wheel back and forth from lock to lock until it stops whining.
The tire pressure issue sounds like one of the sensors has failed or you have low tire pressure. Any tire shop can check the sensors.
https://www.2carpros.com/articles/low-tire-indicator-warning-light
2: The P0513 code means the ECM does not recognize the chip in the key. The chip has failed or its the wrong key for the car.
3: The C0899 code means the main power wire for the ABS controller has low voltage. There should be a power connector with a 12 gauge red and black wire on it. Test the red for 12 volts.
The rest of the scanner readings look normal from what I can see.
Rich.
Sep 10, 2019 at 9:30 PM
CJA31186
  • 89 POSTS
If I take it to a shop, do you have any idea how extensive these repairs would be or how costly?
Sep 11, 2019 at 6:47 PM
94 TRANSAM
  • 680 POSTS
That greatly depends on where you take it. I have seen rate from $80.00 to $200.00 an hour. A lot of shops will do free estimates though.
The first 2 shouldn't be too bad but the ABS power might get pricey if it takes a long time to find the issue.
Rich.
Sep 11, 2019 at 7:35 PM
