Tire monitor system/engine light lights on
192,000 MILES • V6 • 4WD • AUTOMATIC
MAKAYLA.BREANN
My tire sensor was knocked off my car about a month ago. i fixed the valve stem but didn't replace the sensor. I haven't had and issue with any noise but now whenever I'm driving my car it beeps until I stop at a light or am parked and turn off the car. I'm not sure what else could be causing this issue and no one seems to be able to tell me what's wrong or how to fix it. I do have my check engine light on as well but still never had any issues.
Jan 15, 2021 at 3:37 AM
Couple things. Let's start with checking the codes even though it is most likely not related but we need to see what is there just to cover the bases.
Next can you get a recording of what the noise is while you are driving and are their any lights flashing while this is happening?
A video will really help figure this out as it is most likely related to the TPMS but we need to hear it and go from there. Thanks
https://www.2carpros.com/articles/low-tire-indicator-warning-light
Jan 16, 2021 at 2:44 AM
