Tire locks up in drive or reverse
1,600,000 MILES • 2WD • AUTOMATIC
MIKE SINGLETON
After having a low speed blow out my rim was stuck beat it off put on spare and tire locked.
Jul 2, 2017 at 3:23 PM
CARADIODOC
  • 34,414 POSTS
Front or rear? Do you have rear disc brakes? Is it the original or proper spare wheel? Does that wheel skid when you try to drive the vehicle, or are you seeing it is locked up when trying to rotate it by hand when it is jacked up? Can you rotate the brake drum or rotor when the spare is removed?
Jul 2, 2017 at 3:28 PM
RENEE L
  • 1,260 POSTS
Hi MIKE SINGLETON,
Thank you for visiting 2CarPros. Please get back to us with the answer to CARADIODOC's questions so that we can further assist you.
Best regards,
Renee
Admin
Jul 3, 2017 at 2:45 AM
