Tire compatibility
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
BOB01
Can I use an LT245 75R17 in place of a P245 65R17 tire on a 2003 Trailblazer?
Apr 13, 2019 at 10:58 AM
SCGRANTURISMO
  • 4,897 POSTS
Yes. As a matter of fact I would recommend using the "Light Truck" tires as opposed to the "Passenger car" tires as the first letter(s) in the tire size state.
Thanks,
Alex
2CarPros
Apr 13, 2019 at 11:30 AM
BOB01
Awesome! Thank you very much.
Apr 13, 2019 at 11:32 AM
  • 110,248 POSTS
Welcome to 2CarPros.
Just wanted to jump in here. Make sure the LT tire will not rub under the fender. When you change from a 65 to a 75, the tire will be taller and narrower. As far as the LT, I agree with Alex. An LT has a heavier sidewall which is designed to carry more weight. It can be up to a 10 ply sidewall. On the other hand, a P rated tire (passenger tire) will have a 4 ply side wall. It isn't designed for as much weight. Also, the change in size may have an affect on how the vehicle handles.
Apr 15, 2019 at 1:16 PM
