Flapping noise on front right tire
60,000 MILES
FRITZ16
I had my tires rotated. I have a flapping noise on my front right tire. Can you help?
Jan 26, 2019 at 8:41 AM
Good evening,
Were they new or used tires?
My first concern is a bad belt in the tire.
Are all the lugs tight? Loose lug nuts will do this.
Jan 26, 2019 at 9:54 AM
FRITZ16
The tires have 15000 miles on. I do not buy used tires.I had them rotated with my oil change last Friday.
Jan 27, 2019 at 2:15 AM
Did the noise start after rotating the tires?
Jan 27, 2019 at 2:16 AM
FRITZ16
yes
Jan 27, 2019 at 7:03 AM
Ok, then you have a bad tire. That is the only explanation for it.
Have them check the tires in the front.
Jan 27, 2019 at 9:17 AM
