Tipm pinout?
315,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
ROBERT QUEEN
Seems to be a bad connection on the top black c3 connector. You can wiggle the wires and truck will start, runs for a few seconds to a few minutes then shuts off with a no crank no start until you get the wires right again.
Apr 2, 2025 at 12:00 PM
  • 55,694 POSTS
To me it sounds like the TIPM is going out which is common. Here are the C# pinouts as requested. Check out the images (below). Please let us know what happens.
Apr 3, 2025 at 2:57 AM
ROBERT QUEEN
Thanks Ken, additional question, when the truck shuts off, there is a clicking noise from the throttle body, if the clicking stops the truck will crank again. Any idea what would cause this? Most mechanics around here have no clue, but it does through a couple u codes when this clicking starts.
Apr 3, 2025 at 3:19 AM
  • 55,694 POSTS
You are welcome, sorry, we only handle one problem per thread, please post your new question here, you must be logged in.
Cheers, Ken
Apr 4, 2025 at 2:32 AM
