TIPM connectors wiring diagram needed?
200,000 MILES • 6.7L • 6 CYL • 4WD • AUTOMATIC
CHRIS WENTZELL
I have a cab/chassis and I just replaced the TIPM. In the process I had to repair 10 wires due to corrosion, I also had to replace connectors C2 and C6. I would like to find a wiring diagram for these two plugs to make sure I got the pin outs correct.
With the new TIPM installed, the display reads No Fuse, and the wipers turn on.
Feb 8, 2023 at 2:16 AM
  • 110,248 POSTS
I attached a pic of the connectors and how they are oriented. The pics under the connectors provide info on the wiring color, function, pin number and so on. Let me know if this is what you needed.
Take care and let me know if this helps.
See pics below. Connector 2/pics 1, 2, 3. Connector 6/remaining pics.
Feb 8, 2023 at 6:47 AM
LAKECOUNTYCUSTOMS
  • 5 POSTS
Hi JACOBANDNICKOLAS,
I am fixing a harness on a similar truck, 2012 Ram 3500 w/6.7L Diesel. I am looking for the C5 brown harness block pinout please.
Thanks,
Paul
Jan 15, 2025 at 12:18 AM
LAKECOUNTYCUSTOMS
  • 5 POSTS
I am looking for the C5 block pinout for a 2012 3500 with the 6.7L Diesel.
Jan 15, 2025 at 12:43 AM
  • 55,711 POSTS
TRUCKINJAMMA
  • 6 POSTS
Hello
I have a 2010 Dodge Ram 3500 6.7 i acquired in a divorce and just like the ex—- it doesn't wanna work and wants to spend my money. My problem started out as a dead battery situation so a couple guys started listening to my truck and noticed that the fuel pump was staying on so a mechanic Friend put a battery turn off valve. Had that for about three weeks then took a trip about two hours away on the trip home when I got home and turned the truck off, I seen smoke coming from the hood. Long story short, it burnt the TIPM on and the C2 plug. I ordered the TIPM from the Mak site. They sent the blue plug with it. I stripped my wires, went to all the parts stores in town to get the wire ends. Kathy blue plug wiring schematic from someone in a hurry at the dealership in black-and-white. It’s hard to read a little confusing as to which way the wire ends go in and I just need it broke down just a little bit more like I’m in the fifth grade. Can u please help me.
May 8, 2026 at 1:44 PM
  • 55,711 POSTS
Please see this link
https://www.2carpros.com/questions/2010-dodge-3500-laramie--1712715
This will give you the information you need.
May 9, 2026 at 9:19 AM
