TIPM connector pins/wire color to add external fuel pump relay
200,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
REV3-10
Dealer says needs another TIPM the internal fuel pump relay is failing. sometimes no start or takes many tries engine shuts off randomly and the battery gets drained completely sometimes, being that the fuel pump relay sticks in on position with key off engine off. It's is over $1,000.00! Thanks for any help.
Aug 31, 2021 at 5:18 AM
  • 110,248 POSTS
The TIPM unit is a known issue. Oftentimes, the connectors, which have a large number of small connection pins, are where the failure comes from. The pins will corrode or break causing an intermittent issue. So, what they are telling you is likely correct, especially with the number of miles on the vehicle.
What I suggest is this: Replace it yourself. Chances are you can find a new or remanufactured one online for under $500.00. They really aren't that difficult to replace. Once you disconnect the battery, it is a matter of unbolting the unit, disconnecting all the connectors, and then reinstalling everything.
If you look at the pics below, I included the directions for the removal and replacement of the TIPM on this vehicle. Take a look through them to see if you are comfortable doing the job. I will be here to help if you run into trouble.
Aug 31, 2021 at 2:13 PM
