Leaking antifreeze
2013 MINI COUNTRYMAN
80,000 MILES • 4 CYL • 2WD • AUTOMATIC
LINDAPFIO
Small amounts of antifreeze over 2 weeks on ground. How much to fix it?
Nov 29, 2019 at 12:03 AM
AL514
  • 5,668 POSTS
The cooling system will have to be pressure tested to find the leak. There are numerous places it can leak under the car.
https://www.2carpros.com/articles/radiator-pressure-test
Nov 29, 2019 at 4:15 AM
LINDAPFIO
That is what I did and they didn't find any leaks after the pressure test. He did say that since the car has 80,000 miles it could be something internal.Still baffled. any other ideas? Thank you
Dec 1, 2019 at 5:26 AM
  • 55,433 POSTS
Can I ask where under the car is it leaking, front, rear left right of the engine compartment?
This guide can help:
https://www.2carpros.com/articles/car-is-leaking-coolant
Can you please shoot a quick video with your phone so we can see what's going on, that would be great. You can upload it here with your response. Please run down this guide and report back.
Dec 1, 2019 at 5:27 AM
