i want to check the ignition timing?
162,000 MILES • 0.5L • V8 • 2WD • AUTOMATIC
KEVINCOLEY
i want to check the ignition timing, i would like to know the setting?
Sep 3, 2022 at 1:49 AM
  • 55,694 POSTS
This is what they say about the ignition timing.
Base Timing
The distributor ignition system has no provision for timing adjustment. The base timing is preset when the engine is manufactured, and no adjustment is possible.
The distributor may need adjusting to prevent crossfire.
Sep 3, 2022 at 5:15 AM
