timming
1979 PONTIAC TRANS AM
MARSHMAN
The distributor cap will not turn so I can adjust timming on 403 olds engine I loosened the locking bolt.
Apr 27, 2013 at 11:31 AM
HMAC300
  • 48,601 POSTS
put some penetrating oil on this first, then tighten bolt and drive for a few days to let oil soak in around dist. the rubber may be sticky to the intake/block. then see if it will move.
Apr 28, 2013 at 12:45 AM
