Timing procedure
114,871 MILES • 3.5L • V6 • 2WD • AUTOMATIC
DOC BARDEN
Locating the timing marks for the crankshaft gear and also which cylinder should be TDC number one passenger side front or number to driver side front?
Sep 18, 2018 at 8:10 PM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Here is a reference I found for you (attached). Hope this helps and feel free to ask any questions. Thanks for using 2CarPros.
Danny-
Sep 19, 2018 at 8:13 AM
DOC BARDEN
Thank you very much. I am also going to bend your brain I had to eliminate the AC compressor it was junk but I took a pulley off the AC compressor and I am going one belt short or one pulley short rather I just gave never mind. Thank you.
Sep 19, 2018 at 9:22 AM
DANNY L
  • 5,648 POSTS
You are welcome.
Thanks again for using 2CarPros.
Danny-
Sep 19, 2018 at 11:46 AM
DOC BARDEN
Well, I change the water pump lined up all the timing gears get everything right, it will not start, I rechecked everything five times before I put that belt on took care of the tension-er the way it was supposed to be taken care of. I have been without a vehicle for two weeks I have not been able to get to oncology and now I got to spend another twenty hours ripping this motor apart again, thank you very much. I have no clue what happened lined up all timing marks like I was supposed to I even watched about 20 different videos talk to ten different people ask questions just to make sure I can rebuild a CAT engine in my sleep this is the first Isuzu that I put my hands on it is going to be the last. I hate this thing. Thank you again, sincerely
Gunny Doc BARDEN. USMC Ret.
Sep 19, 2018 at 11:54 AM
DANNY L
  • 5,648 POSTS
Hello again.
Just seeing if any progress made. Do you need any more reference material? Hope this helps and thanks again for using 2CarPros.
Danny-
Sep 21, 2018 at 6:15 AM
