Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mitsubishi
Mighty Max
Ignition
Timing
How to set the timing correctly
1988 MITSUBISHI MIGHTY MAX
280,000 MILES • 2.0L • 4 CYL • 2WD
BIGHEAD69
MEMBER
I replace the head I thought I was at top dead center when I pull the head off, but now the engine wont start. how do I get my timing back correct?
Oct 31, 2016 at 1:03 AM
HMAC300
Experienced Mechanic
i am assuming this is a pickup this is for a 2.0 liter which is pictured. silent shaft must be aligned as well. see pictures.
Images (Click to enlarge)
Oct 31, 2016 at 2:35 AM
BIGHEAD69
MEMBER
That worked .What is the correct firing order on a 1988 two liter four cylinder?
Oct 31, 2016 at 6:45 AM
HMAC300
1-3-4-2.
Oct 31, 2016 at 8:13 AM
BIGHEAD69
MEMBER
Thanks for your help. Running OK
Nov 4, 2016 at 9:27 AM
Glad we could get it fixed please use 2CarPros.com anytime we are here to help
Best, Ken
Nov 7, 2016 at 12:27 AM
Add image or video
Ask a new question
Engine won't start
Engine has low power
