Engine shuts off when it reaches operating temperature, is the timing or PCM?
220,000 MILES • 3.3L • V6 • 2WD • AUTOMATIC
RONNIE WOLF
  • 7 POSTS
I had to replace the timing belt cover on my van listed above. After I put everything back together it would not run properly. The mechanic said the PCM went out and I replaced it and the Cam sensor. It'll start but as soon as it gets up to running temperature it shuts off. It sounds good when it's idling.
Jun 22, 2022 at 1:49 PM
  • 110,248 POSTS
Ronnie,
What you describe sounds like an issue with the crankshaft position sensor. When they start to fail, heat adversely affects them.
Take a look through this link and let me know if it mirrors what you experience:
Also, I am assuming that it runs normally before this started. Is that correct?
Jun 22, 2022 at 2:15 PM
RONNIE WOLF
  • 7 POSTS
It runs normally before it heats up. I just replaced the cam sensor.
Jun 22, 2022 at 2:19 PM
RONNIE WOLF
  • 7 POSTS
Do you think I could have a bad sensor?
Jun 22, 2022 at 2:46 PM
  • 110,248 POSTS
Ronnie,
It is possible. If the vehicle has a tachometer, see if it jumps around when it starts running oddly. If the sensor is the issue, the engine will be losing the RPM signal from it, or at least it will be erratic.
Or, if you have a live data scanner, see if the signal jumps around.
Jun 23, 2022 at 12:57 PM
RONNIE WOLF
  • 7 POSTS
Okay, next time I'm around it I'll check it and let you know.
Jun 24, 2022 at 1:50 AM
  • 110,248 POSTS
Sounds good. I'm interested in knowing if that is the issue. Chances are it is something simple.
Take care and I'll watch for your reply.
Jun 24, 2022 at 1:20 PM
RONNIE WOLF
  • 7 POSTS
Okay, thank you.
Jun 24, 2022 at 1:21 PM
RONNIE WOLF
  • 7 POSTS
Replaced the cam sensor for the second time and it runs just great. I really appreciate your help. one more question, I have a hole in my air conditioner condenser can I just replace the condenser or do I have to replace dryer and all that too?
Jun 29, 2022 at 3:16 AM
  • 110,248 POSTS
Ronnie, first, I'm glad to hear it is running properly. That's good news. As far as the AC question, could you possibly copy that question to a new thread? We try to keep the topics specific to one issue, so it is more helpful to others. I hope you understand.
Here is the link to start:
As far as your new question, there are variables and PAG oil will need to be added to the new condenser. I will watch for your new post.
Jun 29, 2022 at 2:55 PM
