Replaced head gasket shaved head and pressure checked. Now put head back on and set timing belt it's backfiring through the throttle body. The timing mark on the cam is below the deep slash on the cam plate and the oil pump is set on the triangle crank on the dot. So what is going on wrong? And it is getting fire and gas. Also checked the fire order.
Oct 19, 2022 at 7:41 AM
