Camshaft timing marks
11,300 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
MIKELL RAMIREZ
Cannot find any references to timing marks.
Jan 12, 2017 at 1:21 AM
HMAC300
  • 48,601 POSTS
there are no timing marks, you must lock down cams with special tool or one like it prior to replacing timing chain. See pictures.
May 30, 2020 at 3:55 AM
YVETTE STRYDOM
Looking for a diagram on engine timing marks can marks is w9 wl.
Nov 11, 2020 at 10:16 AM (Merged)
HMAC300
  • 48,601 POSTS
the sprockets have to come off and use a flat tool to align cams with slots in cam then lock them down and put sprockets on as well as chain. See pictures.
MENDEZ41
Engine Mechanical problem
2001 Ford Ranger 6 cyl Two Wheel Drive Automatic
wat is the timing on the motor it has 3 timg ch i need the crank timig not the cam
Nov 11, 2020 at 10:17 AM (Merged)
  • 110,251 POSTS
I'm not sure I understand what you are asking. If you need a picture of the timing marks, refer to this link near the bottom
https://www.2carpros.com/diagrams/ford/ranger/2001
ELVISRUE
I changed my timing belt and i think i did it right but i have a lifter type sound now since i changed it it is not all the time but once i have made speed and i tap on the gas as i am driving their is a liter noise is because the belt is new
  • 31,937 POSTS
Hi there,
Changing the timing belt if done correctly will not induce any valve noise, i would re check the timing marks and if all is ok, i would think that you have a faulty valve lash adjuster, try an engine flush as this sometime helps with sticky lash adjusters.
mark (mhpautos)
BULLDOG217
Ford, 2002, 3.0 V6, how do you figure when is TDC to install new Camshaft Synchronizer.
Nov 27, 2020 at 2:57 AM (Merged)
FIXITMR
  • 9,989 POSTS
this can be difficult because there is no timing indicator on the front of the engine like the good old days. Here is what the book shows.
You would need to remove the valve cover on the #1 cylinder side and make sure the valves are not open then remove the spark plug on #1 and watch it with a flashlight.
Cheers
