Timing marks and alignment?
272,994 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
AMBI.SKYE
  • 21 POSTS
My timing is off on the vehicle and I'm trying to correct it. I have the Haynes manual but I'm not finding the specifications for one of these sprocket alignments that has a mark. I'm going to include a picture and hopefully that will help to identify where this Mark is supposed to be at and what the actual sprocket is called.
Aug 29, 2022 at 9:29 AM
SQM
  • 6,383 POSTS
Take a look below. You will find the complete timing belt replacement procedure. Including all the markings and sequences.
This procedure is for the 2.3L Non-Vetch.
If you have the Vetch engine just let me know.
https://www.2carpros.com/articles/how-a-timing-belt-works
Aug 29, 2022 at 2:21 PM
AMBI.SKYE
  • 21 POSTS
It is a Vetch motor.
Aug 29, 2022 at 2:43 PM
SQM
  • 6,383 POSTS
See attached for the VTEC timing belt instructions.
Aug 29, 2022 at 3:01 PM
AMBI.SKYE
  • 21 POSTS
Thank you!
I have run into another issue. I've got the timing adjusted accordingly and it's all put back together. The car will start as long as I'm pushing the gas pedal down, but it will not idle. While pushing the gas pedal down it runs smoothly but after it drops below a thousand RPMs it seems to choke out and cuts off.
Sep 3, 2022 at 11:17 AM
SQM
  • 6,383 POSTS
Are you getting any codes?
Sep 5, 2022 at 2:17 PM
