Timing kit replacement, can I get the torque specs to all the bolts?
138,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
SANDRA N JEFFREY SOLIS
I'm looking to get the torque specs to all the bolts pertaining to doing a timing chain replacement kit.
Jul 28, 2022 at 8:33 PM
BORIS K
  • 836 POSTS
Phaser to camshaft bolt 75Nm, 55Ft.lbs.
Timing chain cover M6 bolts 9Nm, 80In.lbs.
Timing chain cover M8 bolts 26Nm, 19Ft.lbs
Timing chain tensioner 10Nm, 89In,lbs.
Timing chain guides 12Nm, 106In.lbs.
Right engine mount bracket M10 bolt 96Nm, 71Ft.lbs.
Oil pan bolts M6 9Nm, 80In.lbs.
Oil pan bolts M8 24Nm, 18Ft.lbs.
Remember to apply RTV to the timing cover mating surfaces.
Hope this helps.
Cheers, Boris
Jul 29, 2022 at 2:01 AM
