Timing issues and codes P0010, P0020, and P0341
72,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
JOEOZZY
Getting errors
P0010- (PCM)
P0020- (PCM)
P0341
It runs relatively fine when cold then when starts warm up it runs rough to the point of shutting down.
Jul 20, 2021 at 12:38 PM
SQM
  • 6,383 POSTS
Here are the codes that you have:
P0010 - Intake Camshaft Position Actuator Circuit/Open (Bank 1)
P0020 - Intake Camshaft Position Actuator Circuit/Open (Bank 2)
P0341 - Camshaft Position Sensor A Circuit Range/Performance (Bank 1 or single sensor)
Code P0341 can happen for a Radio frequency interference/electromagnetic interference or for a damaged cam phaser and sprocket.
Codes P0010 and P0020 can happen for a open or short in the VCT circuit or solenoid.
I have attached a complete diagnostics flow chart (look below) for you to be able to figure out the issue.
https://www.youtube.com/c/2carpros/featured
Jul 20, 2021 at 1:22 PM
