Timing, Idle, Stalling
100,200 MILES • 2.8L • 6 CYL • 4WD • AUTOMATIC
OC_DUDE
Has a high idle 1,000 RPMs in neutral. Randomly stalls when driving, usually when slowing or coming to a stop. Starts right back up. Timing is 14 Degrees at 1,000 RPMs. should be 10 degrees 700.
Checked for vacuum leak.
Replaced thermostat and throttle body gasket which helped a little.
Replaced;
PCV Hose
Valve Cover Gaskets
EGR Valve
O2 Sensor
Spark Plugs
Wires
Air Filter
Distributer Cap
Distributer Rotor
Ignition Module
Fuel Filter
Not sure where to waste money next?
Jun 1, 2022 at 7:58 AM
STEVE W.
  • 15,408 POSTS
Check that the EGR isn't sticking open from carbon.
Jun 1, 2022 at 10:05 AM
OC_DUDE
EGR Valve was replaced.
Jun 1, 2022 at 10:11 AM
STEVE W.
  • 15,408 POSTS
Yes, but the carbon breaks free and can stick it open. Pull the valve and check for carbon build up. They make screens to keep the crud out if needed.
Jun 1, 2022 at 10:45 AM
