timing I think
200,000 MILES
DELUNA5555
1991 Subaru Legacy. Changed timing belt and water pump. Had problems with crank shaft bolt and moved timing. Thought I had readjusted it back to marks put everything together and it won't start. I have since found out that it has computer controlled timing and it isn't adjustable. Don't know what to do please help
Apr 21, 2013 at 3:01 AM
HMAC300
  • 48,601 POSTS
check your compression first to see if you bent valves.
Apr 21, 2013 at 6:18 AM
DELUNA5555
no bent valves
Apr 21, 2013 at 10:10 AM
