I've been drowning in this issue for months with this truck. I can't get it to start. It was rough running before I got the bright idea to change the head gasket. Now my timing is all messed up. I've looked and looked and maybe over looked and over thought the whole process to do it right. I've got the timing tools, cams are right, and the bottom of the weight is hitting the timing peg. Also, the 9th tooth is hitting the crank sensor.. maybe I got the chain wrong if that's possible or I'm missing a step? Not sure. But if anyone has any suggestions, please help.
May 30, 2019 at 6:34 AM
