Car turns on with key but will not start?
130,000 MILES
KAISON
I turn it on I hear the fuel pump engaged, then I try to start, and I get humming. The original issue it had a year ago was the timing. I put it in the shop and the guy gave up and sent it back to me. It was idling at 30 MPH and when I hit the brake it would stall out, any help would be greatly appreciated.
Nov 28, 2022 at 1:17 AM
  • 55,710 POSTS
Can you upload a short video of the engine cranking over so I can see if the engine is in good shape, I can tell from that. Also, we need to check for ignition spark this guide can help you:
https://youtu.be/baq_aEWNQ0Y
This guide can help as well:
https://www.2carpros.com/articles/car-not-running-advanced
Please go over this guide and report back.
Nov 28, 2022 at 9:15 AM
