Timing chain replacement
100,000 MILES • 3.8L • AWD • AUTOMATIC
KEITHMAC
Vehicle will not start. Battery and starter okay. Could timing chain need to be replaced and if so, can you send me step by step instructions? I have more information (Keith is the one fixing it, he was not here when I sent the question). He drove it in the driveway, it was running good, next time he went to start it, it was locked up tight and will not turn over. It is a six cylinder and has 230,000 miles, not 100,000.
Aug 15, 2017 at 12:24 AM
  • 55,686 POSTS
Yes it does sounds like the timing chain broke it which case the engine is no good. I would try to put a long socket wrench on the front of the crankshaft bolt and see if you can get it to turn at all in either direction.
Cheers, Ken
Aug 16, 2017 at 7:38 AM
KEITHMAC
I tried that. It will not turn either way. Is there a way to fix it. If so, how?
Aug 16, 2017 at 12:50 PM
STEVE W.
  • 15,402 POSTS
It would need to be torn down to determine what parts are damaged. If it did break the timing chain you would still need to remove the heads to check for damaged valves/pistons because the 3.8 is an interference engine design. Plus with 230,000 miles on it you would really be better off going through both the top and bottom of the engine, by the time you buy the parts and have the machine work done to make it correct you will have more money into repairing it than a used engine (and probably very close to a factory re-manufactured engine).
Accurate engines gets around $1,600.00 for a re-manufactured with a 100,000 mile warranty.
Aug 16, 2017 at 1:06 PM
