Timing chain replacement
209,000 MILES • 8.1L • V8 • 4WD • AUTOMATIC
BURNSHB1985
I replaced my timing chain, water pump, belts hoses, cam position sensor ACDelco 2133826, and ACDelco 214-1105 GM Original Equipment Vapor Canister Purge Valve. The engine only starts every other attempt, and has been occasionally having a miss or two at stoplights, but otherwise is running strong.
Thank you for your input.
Aug 11, 2019 at 4:57 AM
BURNSHB1985
Here is a video of the issue, which occurs 95% of the time i try to start the engine.
Thanks for looking
Aug 11, 2019 at 5:08 AM
Good afternoon,
Does it crank over when it will not start?
Are there any codes?
Did you clean the throttle body?
https://www.2carpros.com/articles/stall-at-idle
Aug 11, 2019 at 5:10 AM
JIS001
  • 3,412 POSTS
Hi, just wanted to join in as well. The crank no start issue, does it happen when it sits for a few hours or overnight? If that is the issue, I recommend you hook up a fuel pressure gauge. Turn key on and start it. After, shut it off and let it sit and make a note of the pressure when you shut it off and check the pressure again in about an hour. If low, check the fuel pressure regulator for a leak. Here is a link on how to check fuel pressure issues:
Aug 11, 2019 at 9:54 AM
