Timing chain replacement
114,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
WENDIANNA
I need instructions for my mechanic to put the timing chains on my car is there some sort of print out or manual?
Jul 15, 2020 at 4:54 AM
Good afternoon,
Did the timing chains fail? If they did, good chance you have bent valves which will require removal of the heads for inspection. You may have bent valves or damaged pistons. This could result in replacing the engine.
https://www.2carpros.com/articles/how-a-timing-belt-works
I attached 2 youtube videos of the procedure for you.
As far as information, there is a lot. You can go to Alldata.com/diy and get a pass for the car so he can access all the pictures and procedures for the job including the engine if needed.
https://www.youtube.com/watch?v=aKIN8AR95C4
https://www.youtube.com/watch?v=v778P2gb7Dw
Jul 15, 2020 at 7:29 AM
  • 110,248 POSTS
There are three different chains on this engine. I will provide the directions for one at a time. I'm not sure what he is replacing. The attached pics correlate with these directions.
____________________________________
Primary chain
2005 Cadillac Truck SRX 2WD V6-3.6L VIN 7
Primary Camshaft Drive Chain and Sprockets Replacement
Removal Procedure
1. Remove the engine front cover. See: Timing Cover > Service and Repair
2. Remove the right bank secondary camshaft drive chain tensioner. See: Engine Overhaul 22. Secondary Timing Chain Tensioner Removal - Right
3. Remove the right bank secondary camshaft drive chain shoe. See: Engine Overhaul 23. Secondary Camshaft Drive Chain Shoe Removal - Right
4. Remove the right bank secondary camshaft drive chain guide. See: Engine Overhaul 24. Secondary Timing Chain Guide Removal - Right
5. Remove the right bank secondary camshaft drive chain. See: Engine Overhaul 25. Secondary Camshaft Intermediate Drive Chain Removal - Right
6. Remove the primary camshaft drive chain tensioner. See: Engine > Overhaul 26. Primary Camshaft Intermediate Drive Chain Tensioner Removal
7. Remove the primary camshaft drive chain upper guide. See: Engine Overhaul 27. Primary Timing Chain Guide Removal - Upper
pic 1
8. Remove the primary camshaft timing chain. See: Engine > Overhaul > 29. Primary Camshaft Intermediate Drive Chain Removal
Installation Procedure
pic 2
1. Install the primary camshaft timing chain. See: Engine > Overhaul > 120. Primary Camshaft Intermediate Drive Chain Installation
2. Install the primary upper camshaft drive chain guide. See: Engine > Overhaul > 122. Primary Timing Chain Guide Installation - Upper
3. Install the primary camshaft drive chain tensioner. See: Engine > Overhaul > 123. Primary Camshaft Intermediate Drive Chain Tensioner Installation
4. Install the right bank secondary camshaft drive chain. See: Engine > Overhaul > 124. Secondary Camshaft Intermediate Drive Chain Installation - Right
5. Install the right bank secondary camshaft drive chain guide. See: Engine > Overhaul > 125. Secondary Timing Chain Guide Installation - Right
6. Install the right bank secondary camshaft drive chain shoe. See: Engine > Overhaul > 126. Secondary Camshaft Drive Chain Shoe Installation - Right
7. Install the right bank secondary camshaft drive chain tensioner. See: Engine > Overhaul > 127. Secondary Timing Chain Tensioner Installation - Right
8. Install the engine front cover. See: Timing Cover > Service and Repair
_______________________________________
Secondary Camshaft Chain left side
Secondary Camshaft Intermediate Drive Chain Replacement - Left
Removal Procedure
6. Remove the primary camshaft drive chain tensioner. See: Engine Overhaul 26. Primary Camshaft Intermediate Drive Chain Tensioner Removal
7. Remove the primary upper camshaft drive chain guide. See: Engine Overhaul 27. Primary Timing Chain Guide Removal - Upper
8. Remove the primary camshaft drive chain. See: Engine Overhaul 29. Primary Camshaft Intermediate Drive Chain Removal
9. Remove the right bank camshaft intermediate drive chain idler. See: Engine Overhaul 30. Timing Chain Idler Sprocket Removal - Right
10. Remove the left bank secondary camshaft drive chain tensioner. See: Engine Overhaul 31. Secondary Timing Chain Tensioner Removal - Left
11. Remove the left bank secondary camshaft drive chain shoe. See: Engine Overhaul 32. Secondary Camshaft Drive Chain Shoe Removal - Left
12. Remove the left bank secondary camshaft drive chain guide. See: Engine Overhaul 33. Secondary Timing Chain Guide Removal - Left
13. Remove the left bank camshaft intermediate drive chain idler. See: Engine Overhaul 35. Timing Chain Idler Sprocket Removal - Left
pic 3
14. Remove the left bank secondary camshaft drive chain. See: Engine Overhaul 34. Secondary Camshaft Intermediate Drive Chain Removal - Left
15. Clean and inspect all of the camshaft timing drive components. Replace components as necessary. See: Engine Overhaul 70. Camshaft Timing Drive Components Clean and Inspect
pic 4
1. Install the left bank secondary camshaft drive chain. See: Engine Overhaul 115. Secondary Camshaft Intermediate Drive Chain Installation - Left
2. Install the left bank camshaft intermediate drive chain idler. See: Engine Overhaul 114. Timing Chain Idler Sprocket Installation - Left
3. Install the left bank secondary camshaft drive chain guide. See: Engine Overhaul 116. Secondary Timing Chain Guide Installation - Left
4. Install the left bank secondary camshaft drive chain shoe. See: Engine Overhaul 117. Secondary Camshaft Drive Chain Shoe Installation - Left
5. Install the left bank secondary camshaft drive chain tensioner. See: Engine Overhaul 118. Secondary Timing Chain Tensioner Installation - Left
6. Install the right bank camshaft intermediate drive chain idler. See: Engine Overhaul 119. Timing Chain Idler Sprocket Installation - Right
7. Install the primary camshaft drive chain. See: Engine Overhaul 120. Primary Camshaft Intermediate Drive Chain Installation
8. Install the primary upper camshaft drive chain guide. See: Engine Overhaul 122. Primary Timing Chain Guide Installation - Upper
9. Install the primary camshaft drive chain tensioner. See: Engine Overhaul 123. Primary Camshaft Intermediate Drive Chain Tensioner Installation
10. Install the right bank secondary camshaft drive chain. See: Engine Overhaul 124. Secondary Camshaft Intermediate Drive Chain Installation - Right
11. Install the right bank secondary camshaft drive chain guide. See: Engine Overhaul 125. Secondary Timing Chain Guide Installation - Right
12. Install the right bank secondary camshaft drive chain shoe. See: Engine Overhaul 126. Secondary Camshaft Drive Chain Shoe Installation - Right
13. Install the right bank secondary camshaft drive chain tensioner. See: Engine Overhaul 127. Secondary Timing Chain Tensioner Installation - Right
14. Install the engine front cover. See: Timing Cover Service and Repair
_________________________________________________
Secondary Camshaft Right Side
Secondary Camshaft Intermediate Drive Chain Replacement - Right
Removal Procedure
1. Remove the engine front cover. See: Timing Cover Service and Repair
pic 5
1. Ensure the stage 1 camshaft timing is correct. See: Timing Component Alignment Marks Procedures Timing Chain Alignment Diagram
pic 6
2. Install the right bank secondary camshaft drive chain. See: Engine Overhaul 124. Secondary Camshaft Intermediate Drive Chain Installation - Right
3. Install the right bank secondary camshaft drive chain guide. See: Engine Overhaul 125. Secondary Timing Chain Guide Installation - Right
4. Install the right bank secondary camshaft drive chain shoe. See: Engine Overhaul 126. Secondary Camshaft Drive Chain Shoe Installation - Right
5. Install the right bank secondary camshaft drive chain tensioner. See: Engine Overhaul 127. Secondary Timing Chain Tensioner Installation - Right
6. Install the engine front cover. See: Timing Cover Service and Repair
Let me know if this helps or if you have other questions. I have to be honest, this isn't an easy job. I'm a bit concerned that your mechanic doesn't have access to this type of info if he is doing the job.
Feel free to let me know if you have other questions or need help.
Jul 15, 2020 at 7:38 AM
