Timing chain replacement
3.7L
JOSE GARCIA2
  • 8 POSTS
Need information and steps on how to replace timing chain/synchronizer for the truck listed above.
Nov 18, 2019 at 7:39 AM
  • 110,246 POSTS
Hi.
Here are the directions for removal/replacement. The attached pictures correlate with the directions.
__________________________________________________________________________________________
2007 Dodge or Ram Truck RAM 1500 Truck 2WD V6-3.7L VIN K
Removal
Vehicle Engine, Cooling and Exhaust Engine Timing Components Timing Chain Service and Repair Removal and Replacement Timing Chain & Sprockets Removal
REMOVAL
REMOVAL
pic 1
pic 2
1. Disconnect negative cable from battery.
2. Drain cooling system.
3. Remove right and left cylinder head covers.
4. Remove radiator fan shroud.
5. Rotate engine until timing mark on crankshaft damper (2) aligns with TDC mark on timing chain cover (2) and the camshaft sprocket "V6" marks are at the 12 o'clock position (No. 1 TDC exhaust stroke).
pic 3
6. Remove power steering pump.
7. Remove access plug from left and right cylinder heads for access to chain guide fasteners.
8. Remove the oil fill housing to gain access to the right side tensioner arm fastener.
9. Remove crankshaft damper and timing chain cover.
pic 4
10. Collapse and pin primary chain tensioner.
CAUTION: Plate behind left secondary chain tensioner could fall into oil pan. Therefore, cover pan opening.
11. Remove secondary chain tensioners.
12. Remove camshaft position sensor (2).
CAUTION: Care should be taken not to damage camshaft target wheel. Do not hold target wheel while loosening or tightening camshaft sprocket. Do not place the target wheel near a magnetic source of any kind. A damaged or magnetized target wheel could cause a vehicle no start condition.
CAUTION: Do not forcefully rotate the camshafts or crankshaft independently of each other. Damaging intake valve to piston contact will occur. Ensure negative battery cable is disconnected to guard against accidental starter engagement.
13. Remove left and right camshaft sprocket bolts.
14. While holding the left camshaft steel tube with Special Tool 8428 Camshaft Wrench (2), remove the left camshaft sprocket. Slowly rotate the camshaft approximately 5 degrees clockwise to a neutral position.
15. While holding the right camshaft steel tube with Special Tool 8428 Camshaft Wrench (2), remove the right camshaft sprocket.
16. Remove idler sprocket assembly bolt.
17. Slide the idler sprocket assembly and crank sprocket forward simultaneously to remove the primary and secondary chains.
18. Remove both pivoting tensioner arms and chain guides.
19. Remove primary chain tensioner.
Installation
Vehicle Engine, Cooling and Exhaust Engine Timing Components Timing Chain Service and Repair Removal and Replacement Timing Chain & Sprockets Installation
INSTALLATION
INSTALLATION
pic 5
1. Using a vise, lightly compress the secondary chain tensioner piston (5) until the piston step is flush with the tensioner body. Using a pin or suitable tool, release ratchet pawl by pulling pawl back against spring force through access hole on side of tensioner. While continuing to hold pawl back, Push ratchet device to approximately 2 mm from the tensioner body. Install Special Tool 8514 lock pin (3) into hole on front of tensioner. Slowly open vise (1) to transfer piston spring force to lock pin.
2. Position primary chain tensioner over oil pump and insert bolts into lower two holes on tensioner bracket. Tighten bolts to 28 Nm (250 in. lbs.).
pic 6
3. Install right side chain tensioner arm. Install Torx(R) bolt. Tighten Torx(R) bolt to 28 Nm (250 in. lbs.).
CAUTION: The silver bolts retain the guides to the cylinder heads and the black bolts retain the guides to the engine block.
4. Install the left side chain guide. Tighten the bolts to 28 Nm (250 in. lbs.).
5. Install left side chain tensioner arm, and Torx(R) bolt. Tighten Torx(R) bolt to 28 Nm (250 in. lbs.).
6. Install the right side chain guide. Tighten the bolts to 28 Nm (250 in. lbs.).
7. Install both secondary chains onto the idler sprocket. Align two plated links on the secondary chains to be visible through the two lower openings on the idler sprocket (4 o'clock and 8 o'clock). Once the secondary timing chains are installed, position special tool 8429 (1) to hold chains in place for installation.
8. Align primary chain double plated links with the timing mark at 12 o'clock on the idler sprocket. Align the primary chain single plated link with the timing mark at 6 o'clock on the crankshaft sprocket.
9. Lubricate idler shaft and bushings with clean engine oil.
pic 7
NOTE: The idler sprocket must be timed to the counterbalance shaft drive gear before the idler sprocket is fully seated.
10. Install all chains, crankshaft sprocket, and idler sprocket as an assembly. After guiding both secondary chains through the block and cylinder head openings, affix chains with a elastic strap or equivalent. This will maintain tension on chains to aid in installation. Align the timing mark (2) on the idler sprocket gear (3) to the timing mark on the counterbalance shaft drive gear (1), then seat idler sprocket fully. Before installing idler sprocket bolt, lubricate washer with oil, and tighten idler sprocket assembly retaining bolt to 34 Nm (25 ft. lbs.).
pic 8
NOTE: It will be necessary to slightly rotate camshafts for sprocket installation.
11. Align left camshaft sprocket "L" dot to plated link on chain.
12. Align right camshaft sprocket "R" dot to plated link on chain.
CAUTION: Remove excess oil from the camshaft sprocket bolt. Failure to do so can result in over-torque of bolt resulting in bolt failure.
13. Remove Special Tool 8429, then attach both sprockets to camshafts. Remove excess oil from bolts, then Install sprocket bolts, but do not tighten at this time.
14. Verify that all plated links are aligned with the marks on all sprockets and the "V6" marks on camshaft sprockets are at the 12 o'clock position.
pic 9
pic 10
CAUTION: Ensure the plate between the left secondary chain tensioner and block is correctly installed.
15. Install both secondary chain tensioners. Tighten bolts to 28 Nm (250 in. lbs.).
NOTE: Left and right secondary chain tensioners are not common.
16. Remove all 3 locking pins from tensioners.
CAUTION: After pulling locking pins out of each tensioner, DO NOT manually extend the tensioner(s) ratchet. Doing so will over tension the chains, resulting in noise and/or high timing chain loads.
17. Using Special Tool 6958, Spanner with Adaptor Pins 8346, (4) tighten left and right camshaft sprocket bolts to 122 Nm (90 ft. lbs.).
18. Rotate engine two full revolutions. Verify timing marks are at the follow locations:
- primary chain idler sprocket dot is at 12 o'clock
- primary chain crankshaft sprocket dot is at 6 o'clock
- secondary chain camshaft sprockets "V6" marks are at 12 o'clock
- counterbalancer shaft drive gear dot is aligned to the idler sprocket gear dot
19. Lubricate all three chains with engine oil.
pic 11
20. After installing all chains, it is recommended that the idler gear end play be checked. The end play must be within 0.10-0.25 mm (0.004 - 0.010 in.). If not within specification, the idler gear must be replaced.
21. Install timing chain cover and crankshaft damper. Refer to procedures.
22. Install cylinder head covers.
pic 12
NOTE: Before installing threaded plug in right cylinder head, the plug must be coated with sealant to prevent leaks.
23. Coat the large threaded access plug with Mopar(R) Thread Sealant with Teflon, then install into the right cylinder head (1) and tighten to 81 Nm (60 ft. lbs.).
24. Install the oil fill housing.
25. Install access plug in left cylinder head (2).
26. Install power steering pump.
27. Fill cooling system.
28. Connect negative cable to battery.
Nov 18, 2019 at 12:42 PM
