Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Dakota
Engine
Timing Chain
Replace/Remove
timing chain problems
2002 DODGE DAKOTA
160,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
ERICSCOTTHILL
MEMBER
Do I need to change all three chains or just the main one?
Feb 16, 2016 at 8:07 AM
JOHNNYT73
Experienced Mechanic
I'm guessing your doing a 4.7? If the answer is yes, you do need to replace all chains, guides, and tensioners.
Feb 16, 2016 at 9:12 AM
ERICSCOTTHILL
MEMBER
Anything else I need to do?
Feb 16, 2016 at 10:29 AM
JOHNNYT73
With mileage on your truck if it hasn't already been done I suggest changing the oil pump while you are there?
Feb 16, 2016 at 10:40 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
