Timing chain just changed, attempted to accelerate it shut off and has not started since
170,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
1269MEBB
After changing the timing it ran for approximately 35 minutes and upon getting off the exit ramp I slowed to a stop and when I attempted to accelerate it shut off and hasn't started since.
Sep 8, 2019 at 10:49 AM
  • 110,248 POSTS
Welcome to 2CarPros.
The first thing we need to check is if the engine is getting spark and fuel. Take a look through this link:
Here are a couple links for checking fuel pressure and for ignition spark:
To make it really easy, see if the engine starts for a couple seconds using starting fluid. If it does, then it is a fuel related issue. If it still doesn't start, then it is most likely related to an ignition problem.
Sep 8, 2019 at 11:45 AM
