Top bolt missing on top of fixed timing chain guide. Will this hurt anything if it is not there?
May 15, 2020 at 9:13 AM
✓Experienced Mechanic
Hi Jeffrey,
I attached an exploded view below. Identify which part you are referring to. Also, was the bolt forgotten?
Image (Click to enlarge)
May 15, 2020 at 1:46 PM
JEFFREY PADBURY
MEMBER
Chain vibration damper, yes forgotten.
May 15, 2020 at 2:41 PM
It needs to be installed. That absorbs vibration and it will move without the top bolt. If you need directions for timing chain removal and replacement, let me know.
