Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Saturn
SW2
Engine
Timing Chain
Cover
Timing chain cover
1998 SATURN SW2
300,000 MILES • 1.9L • 4 CYL • 2WD
UNCLEBIFF
MEMBER
When I removed the timing chain cover the piece where the pulley bolts on seems to have broke off. Is it replaceable?
Nov 25, 2018 at 4:52 AM
Experienced Mechanic
Good afternoon,
Can you post a picture of what you see?
Do you mean the tension-er or the cam or crank pulley?
Image (Click to enlarge)
Nov 25, 2018 at 5:04 AM
UNCLEBIFF
MEMBER
This is front and back view it looks like some kind of insert. I do not know if it is factory.
Images (Click to enlarge)
Nov 25, 2018 at 6:02 AM
Okay, that is for the pulley for the drive belt.
Yes, replace the cover. You would be much better off getting that new part.
You can call a gm dealer for the part as Saturn is under the GM umbrella.
Nov 25, 2018 at 6:30 AM
Add image or video
Ask a new question
Engine won't start
Engine overheating
