Timing chain
333,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
BOB19;7
This is the third timing chain I have replaced on this truck. the first two went flawlessly. Also, replaced CSP sensor, all four oxygen sensors and air idle sensor. Truck ran fine prior to change now runs extremely rough. Suggestions?
Nov 5, 2016 at 11:24 AM
  • 55,770 POSTS
Hey Bob,
This sounds like you may have bent a valve, lets do a compression check to see if there are any low cylinders.
Here is a guide to help
Please let us know what you find so it will help others.
Best, Ken
Nov 7, 2016 at 2:16 AM
